Hi, I was trying to control 10 Leds with the arduino Through the serial monitor, does anybody know how ?
Genius 470 (author) 3 years ago
I was wondering if i could modify this code so i could control the led's with the serial monitor, but i don't know how, Could somebody help?
int pin2 = 2;
int pin3 = 3;
int pin4 = 4;
int pin5 = 5;
int pin6 = 6;
int pin7 = 7;
int pin8 = 8;
int pin9 = 9;
int pin10 = 10;
int pin11 = 11;
int timer = 60;
void setup(){
pinMode(pin2, OUTPUT);
pinMode(pin3, OUTPUT);
pinMode(pin4, OUTPUT);
pinMode(pin5, OUTPUT);
pinMode(pin6, OUTPUT);
pinMode(pin7, OUTPUT);
pinMode(pin8, OUTPUT);
pinMode(pin9, OUTPUT);
pinMode(pin10, OUTPUT);
pinMode(pin11, OUTPUT);
void loop() {
digitalWrite(pin2, HIGH);
delay(timer);
digitalWrite(pin2, LOW);
delay(timer);
digitalWrite(pin3, HIGH);
delay(timer);
digitalWrite(pin3, LOW);
delay(timer);
digitalWrite(pin4, HIGH);
delay(timer);
digitalWrite(pin4, LOW);
delay(timer);
digitalWrite(pin5, HIGH);
delay(timer);
digitalWrite(pin5, LOW);
delay(timer);
digitalWrite(pin6, HIGH);
delay(timer);
digitalWrite(pin6, LOW);
delay(timer);
digitalWrite(pin7, HIGH);
delay(timer);
digitalWrite(pin7, LOW);
delay(timer);
digitalWrite(pin8, HIGH);
delay(timer);
digitalWrite(pin8, LOW);
delay(timer);
digitalWrite(pin9, HIGH);
delay(timer);
digitalWrite(pin9, LOW);
delay(timer);
digitalWrite(pin10, HIGH);
delay(timer);
digitalWrite(pin10, LOW);
delay(timer);
digitalWrite(pin11, HIGH);
delay(timer);
digitalWrite(pin11, LOW);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
delay(timer);
No, you need to start with what I posted, after you've learned how to listen to the serial port.
Yes, Here's one method, it will allow you to put any combination of 10 LEDs on or off at once
Fasten all the LEDs to the Arduino pins.
Read a number from the serial port
if ( (number&1)==1) led1=1 else led1=0;
if ((number&2)==2) led2=1 else led2 =0;
if ((number&4)==4) led3=1 else led3 =0;
if ((number&8)==8) led4=1 else led4 =0;
if ((number&16)==16) led5=1 else led5 =0;
if ((number&32)==32) led6=1 else led6 =0;
if ((number&64)==64) led7=1 else led7 =0;
if ((number&128)==128) led8=1 else led8 =0;
if ((number&256)==256) led9=1 else led9 =0;
if ((number&512)==512) led10=1 else led10 =0;
There are other ways, but this is the easiest method for a beginner.
Genius 470 (author)  steveastrouk3 years ago
Thank you for you answer, But could you explain a little bit more, because i'm only 13 and i just started using arduino and the coding.
Do this in stages then. Take a look at the serial programming samples in the Arduino code and try them out. Make them turn on and off one LED first. Then come back and look how, if you enter a number from 0..1024, my code works.
Need lots more information here. What code are you using? What LEDs are you using? How do you have everything wired?
Genius 470 (author)  mpilchfamily3 years ago
I'm using a led bargraph wired through pins of 2 through 11 of a arduino uno.
