Hi! I would like to make a hand crank cell phone charger....
Hi everybody, How would I make a hand crank cell phone charger from scratch (meaning, not just taking a hand crank flashlight and rigging it to charge a phone). I would really like to understand the electronics behind it all. I think this would be extremely useful if my phone died and I had no outlet available. I know I'd have to use a small motor, but how many volts? amps? etc. Thank you so much! patti :)
Patti.....I commend your enthusiasm with wanting to create such a device!!!
"However", (Nicer then But..lol). I will give you this link where you can purchase it for less then $5.00 w/free shipping? Why not give yourself a treat!
Then if you so desire....buy 2 and take one apart to reverse engineer it.
Sound O.K.? Also alot of other cool fun cheap as hell stuff there..especially for cell phone tricking. http://www.dealextreme.com/
csh268 years ago
I was just watching a video on youtube recently about that. Here it is.
orksecurity8 years ago
It will take a fairly obscene amount of cranking; cell phones draw a lot of juice. For comparison: Fifteen minutes of cranking on a commercially-made (Eton) emergency light/radio/phone-charger may only charge a phone enough to make a one-minute call, according to the user's manual. If that doesn't put you off: The motor acts as a generator, hopefully producing a voltage higher than needed to charge the phone -- if not, you need to put it through a transformer to get that higher voltage, at the cost of losing some power. The voltage is then rectified and put through a regulator circuit to smooth it out (typically at 5V, for USB-charged phones), and you then hook that up to the phone as usual. Theoretically any permanent-magnet motor can be used as a somewhat inefficient generator; the differences are in how fast you'd have to crank it to get a given amount of voltage out and how quickly you'd destroy the motor in the process.
mckywer (author)  orksecurity8 years ago
Wow - a lot of work it seems like, but awesome. Thanks for the answer - VERY informative!!!
jj378 years ago
as for the volts check the back of your phone battery
mckywer (author)  jj378 years ago
thank you!
