Hi, can you tell me how to make rope pump step by step?
P.S. Sorry for my spelling...
It should look like this:
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
A Pulley
A rope either knotted to just fit the pipe or you can knot sponges or rags to it to improve the lifting ability.
A suitably long pipe to reach the water supply.
The rope turns round the pulley in an endless loop
As the rope turns water is lifted up the pipe because the knots or rags fill up the space in the pipe, some leaks back but a lot gets lifted.
At the top the water just pours out of the outlet pipe.
i have made these with plastic drain pipes and PVC water pipes.
its very simple but it works and is LOW LOW tec.
http://www.arvindguptatoys.com/arvindgupta/pumps.pdf
This PDF tells an interesting story about building all sorts of pumps in Indian schools to teach engineering principles.
I've been working on a seedling table and may incorporate one for giggles (rube goldberg value) to power my 'shower' watering grid, so I can keep the reservoir down below the lighting rather than perching it above to minimize potential crises.
