3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hog Hunting with OUTDOOR LED LIGHTS?
I am wanting to hook up some solar powered red led lights at My deer lease to hunt hogs with. The light will have to be bright enough for Me to be able to see the hogs with My scope from about 100 yeards away. I know nothing about how to hook this up, what I need to buy, but I am handy to some degree. Any help would be great
Oct 31, 2011. 11:31 AM830girl says:
Check out www.wildcatlighting.com
Oct 4, 2009. 2:24 AMwccolvin says:
I beleive Texas Boars and Hog Hunting Guide both have Forums that give you FREE detailed information on building LED Hog Lights.Just do a GOOGLE or YAHOO search for Hog Lights and you should be able to find the information you are looking for.Then you can go to E-bay and Order your LED's.
May 14, 2009. 11:07 AMBig Daddy Himself says:
HuntSports offers what I believe to be the best set of BUILD YOUR OWN HOG HUNTING LIGHT PLANS ... and when completed ... the BEST HOG HUNTING LIGHT you can get anywhere! ALL SOLAR POWER .. 12VDC ... come On @ DUSK , and OFF @ Dawn ... they are listed on Ebay as .. DIY BUILD YOUR OWN HOG FEEDER L.E.D. HUNTING LIGHT FROM PLANS HuntSportsHogLights™ BigDaddysSuperBrightLights™ HuntSportsBoarLights™ BarrelLidHogLights™ FeederLidLights™ Dusk2DawnFeederLights™ Dusk2DawnInfraredLights™ FeederLegLights™ Dusk2DawnInfraredLights™ Build Your Own DIY PLANS & Outlines ONLY $ 9.99 Or you can get direct at HuntSports
Mar 17, 2009. 10:43 PMfrollard says:
It wouldn't be hard to build. You'd need some LEDs, and some cheap solar lights. Solar lights run white leds at 3-4 volts. RED leds require less, 2-3 volts. You would want to replace each 1 white led with 2 red leds in series. Leave everything else intact.
Apr 21, 2009. 4:28 PMBig Daddy Himself says:
I've done lot's and lots of testing of lights , LEDS and brightness testing and those garden solar lights are a waste of time and money
Apr 22, 2009. 4:07 PMfrollard says:
well, they're designed for accent lighting, not functional lighting...
May 14, 2009. 11:08 AMBig Daddy Himself says:
Jan 26, 2012. 7:49 PMbjones4564 says:
i watched your spots on hunt sports and realy excited to build some already bought 2 big led tail lights tested tham last night on a marine battery wondering what is the smallest 12volt will run and all the other hook ups
Jan 27, 2012. 6:29 AMhuntsportsbigdaddy says:
You can use almost any 12V system .. the problem is - HOW LONG THEY WILL RUN .. and how bright .. the bigger the power source and one with rechargeable capability ( ie SOLAR PANEL ) .. and dusk to dawn switching OR remote control .. will work best - save yourself a lot of time and heartache - go to www.huntsports.com and get my HogLight Deer FeederLight Plans for $ 19.99
Mar 18, 2009. 12:48 PMfrollard says:
Just remember that leds are polarized, meaning they have a distinct + and -. http://www.instructables.com/id/LED_Polarity_Tester/ has useful information for figuring this out.
Start by using a multimeter (they're inexpensive for the hobby ones) to check the voltage at the led when the unit is on. If you start with solar lights with AMBER bulbs in them, the voltage may be compatible with the red leds out of the chute, no major changes necessary. White DOES require higher voltage, and that higher voltage will damage your red diodes.
Taking out the old led will be easy as well...heating up the solder joints, and pulling gently. There will be a resistor in series, likely on the circuit board (follow the traces, you'll see it). Its value will be important in regulating the original led. Hook up 1 or 2 leds to the spot (in series, + to -, + to -) where the old led was. Both should shine when power is applied.
Why are they different voltages? The chemistry that makes up the diode itself is different in different colours, and each requires a different amount of power.
Mar 18, 2009. 12:49 PMfrollard says:
ooh ooh, worst case scenario - put a red filter over the white led. it's a bit wasteful, but really, a white led is a 'multicolour' led, you'd just filter out the non-white.
Apr 12, 2009. 8:39 PMBig Daddy Himself says:
The Best LED Solar power and dawn to Dusk light set up you can get is avaialbale at HuntSports.com ... we have the LED SOLAR BUILD YOUR OWN PLANS ... the "kit" with ALL PARTS and you assemble and save ... OR you can buy the whole enchilada!! any questions email BigDaddy @ HuntSports
Mar 17, 2009. 9:31 PMLinuxH4x0r says:
Be careful, some states ban hunting with artificial lights (minnesota for example)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
