How can I chip a dynamo on a vintage car so that it will give out amperage to meet the draw from lamps etc?
phlize (author) 7 years ago
Thanks for your reply. I am running 12volt system. I'm in the UK & the Vintage Sports Car Club here do not allow modifications such as fitting an alternator. So even for night rallies in winter you would be disqualified for running with one!! I read somewhere that the old dynamo could be "chipped" to give an output hat varied with the demand - going higher than the standard 10 amps if required but cannot find any detail on how to do it.
Re-design7 years ago
If you are trying to get more amps out of the original product you probably can't.  What most people do in adapt a modern alternator, even though it's not original style.  If you are showing the car, most judges allow for safety improvements, atleast in the shows I exibited my '32 Ford in.
It would be easy to get a more modern and powerful generator or adapt a modern alternator to your car.  There are kits that have instructions and brackets.  Part of the problem is that you are running 6 volts and there is a reason that no one builds cars using 6 volt systems anymore, a 12 volt system is just a better system.
I concur with you there.
L
