loading
How can I connect a micro camera (a tiny spy one) to a small 4.5"-6.5" LCD screen to work as a sort of spy screen?
If you've played Modern Warfare 2, you know what the Heartbeat Sensor is. It's a small screen that is attached to the side of a firearm and is connected by visible wiring to some other unknown electronic parts.
Really, though, I'm looking to recreate the screen concept as a camera + viewing screen that will work in low-light environments, specifically for paintball scenarios. I can make the outer shell and make sure it won't be ruined by a stray shot, but actually connecting the mini camera to the screen and having them work at all is an issue, and even more is having it work at night or in dark areas. I have basically no experience with electronics aside from plugging part A into slot A, part B into slot B, etc. I can work with computers easily, but physical wiring and such is a total blank card for me.
I'd also like to know whether it'd require a specific screen to work. I'm completely open to suggestions, as long as the net weight of everything required doesn't exceed a few pounds, as the gun itself is already starting to lean towards the weight of actual firearms.
