How can I control the speed of a 7A 12v motor?
17
answers
Answer it!
Steve
Thank you very much!
http://maplin.co.uk/module.aspx?moduleno=30310
You'll have to beef up that output transistor - don't know what they used, but take it off and put it on a better heatsink for a start .
Unless you are short of energy, re-design has a good idea.
| Specifications: | |
| Input voltage: | 6 - 15V |
| Output voltage: | modulated relative to input |
| Loading: | 3A cont. 5A peak |
| Weight: | 30g |
| Dimensions: | 61 x 41 x 40mm |
Like I said, the Maplin one needed the transistor beefing up for 7A
Steve
example "Dimmer Switch":
http://home.howstuffworks.com/dimmer-switch1.htm
This can be reconfigured to operate on a single rail, using two 10k resistors to reach the midpoint of the voltage supply, and using this instead of the earth in the oscillator. For simplicity, it can use the same supply as the motor.
The output can then be used to trigger a transistor, which is used to drive the motor. The transistor may require a heat sink.
