How can I convert my 35mm Film SLR Camera to a Digital SLR camera?
I Have an old SLR camera in excellant condition. It requires 35mm film. I want to convert in into a Digital camera. How Can I do that? Can I use sort of CMOS sensor at the place of film? Please help me!
Not Easily. If you had a medium-format camera, you'd be able to swap in a digital back unit. There were some early efforts to work up something similar in the way of a replacement back door for SLRs (or those SLRs which can have their doors replaced, anyway, which tends to be the pro units) that carried the CCD, but getting the CCD to exactly the right film plane so everything would focus right and handling all the other details (different frame size, etc.) proved to simply be impractical.
Rather than destroying an old camera, I'd suggest selling it and using the proceeds to buy a used digital SLR. Third-generation DSLRs are available used for reasonable prices (as cameras go). Depending on your current system, you may or may not be able to use your existing lenses with the new digital -- Canon is the major exception, alas, since they completely changed the lens mounts and it isn't even possible to get a kluge adapter between the two.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
