How can I get a solid chunk of Pyrite / Fool's Gold?
I could buy it from the gem store, but this will defeat the purpose of the project.
Thank you for you help :D
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
This page gives sort of an overview of different methods for growing synthetic crystals
http://chemistry.osu.edu/~woodward/Lect3_754.htm
One of those methods is slow cooling of a liquid. The Czochralski method (http://en.wikipedia.org/wiki/Czochralski_process)is well known example of these. It is well known since it is used for making large single crystals of pure silicon, which are cut into wafers for making computer chips.
An overview of several of these slow cooling of a liquid methods (Verneuil Method, Czochralski Method, Bridgman Method, Kyropulos Method, Bagdasarov Method, and a few others) can be found here:
http://mtixtl.com/introductiononbasiccrystalgrowthmethods.aspx
The trouble with iron pyrite though, is that I don't think it is going to melt at ordinary pressures. The Wikipedia article on "Pyrite",
(http://en.wikipedia.org/wiki/Pyrite) in the "Uses" section there is a paragraph that says Pyrite decomposes at around 550 C.
"Thermal decomposition of pyrite into FeS (iron(II) sulfide) and elemental sulfur starts at 550 °C; at around 700 °C pS2 is about 1 atm."
The reaction for that is:
FeS2(s) = FeS(s) + S(g)
So I am guessing a very high pressure (of sulfur gas) would be needed to push that equilibrium back towards the left. Also guessing that such conditions exist deep underground, and that's how natural iron pyrite forms.
I don't know what you'd need to do to make this happen in the lab.
I'm not saying it is impossible, just that I think making large crystals of iron pyrite using one of the melt-with-slow-cooling methods, is going to be tricky.
Of course there were other tricks that I don't know much about either, like that vapor transport, or vapor deposition mentioned in the first link.
If you could figure out how to grow thin films of iron pyrite, maybe you could sort of make a fake big crystal by growing a thin layer of pyrite on a cube shaped substrate made of something else?
Like they do with those titanium nitride coated drill bits,
http://en.wikipedia.org/wiki/Titanium_nitride
Coincidentally, that TiN stuff kind of looks like gold too.
There is an issue, I do not know if synthetically it would still work the same as a natural occuring cube. It may loose its electrical properties. Thanks for the answer
A shorter answer is that I think the equipment and time required to do this would be much more expensive than just buying a chunk of pyrite, from somebody on eBay, or wherever else rocks like this are sold.
I have not seen a lot of pyrite where I live, but apparently in some places it is common like dirt, or like you were saying, like river sand.
You are spot on for the "use of a detector", this is the exact reason I want it, ( making a radio from scratch, instructible in the making now, 80% complete-ish )
"is there anything (author) doesn't know?"
...not sure. When in doubt look it up :)
http://en.wikipedia.org/wiki/Iron_pyrite
