3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How can I improve the bass response in my SET vacuum tube amplifier?
Hello instructables,
I'm experiencing an odd problem with my new SET amplifier. I just built Fred Nachbaur's MiniBlok 13EM7 SET amplifier and the bass response is poor with the power turned on, but when I turn off the plate supply and allow the amplifier to run on the energy stored in the capacitors, there is an immediate and very audible change in the rendering of the lower frequencies. I followed the schematic as closely as I could, but until my Edcor 10k:8 Ohm Output Transformer arrives, I am using a small 2K:8 Ohm Output Transformer from an old transistor amplifier. I have tried to install a filter choke and another capacitor in the power supply, but this did not improve the audio quality. Does anyone have any advice? Is the output transformer the problem, and if so, why?
Thank you!
May 8, 2010. 4:46 PMgmoon says:
While many people tout the effects of using an undersized OT ("core saturation" :-P ) one thing you will NOT get with an undersized transformer is bass response.
Maybe the sound improves when you cut the power because the OT isn't over-saturating anymore.
And a 2K load resistance is WAY off what he's using in that schematic. Your new Edcor trannie is very close though:
35:1 winding = 1224:1 impedance, or 9.8K:8.
Assuming that's the root of your problem, the new transformer should make a big difference...
May 8, 2010. 5:25 PMgmoon says:
Hmmm. I just looked up the 13EM7.
The datasheet doesn't spec a load resistance. But using two ways I know of finding the correct load resistance:
1) For triodes, the OT Z is about 2-4 times the Rp (plate resistance) value.
The Rp is ~750 ohms @ 150V. Three times that is 2250 ohms.
(Unfortunately, the datasheet give Rp for only 150V.)
2) The other formula is
Zout = Va/(Pa/Va), where
Va = plate voltage (150V)
Pa = max plate dissipation (10 watts)
150 / (10/150) = 2250 ohms. That follows--also for a plate voltage of 150V.
Of course, Fred's schematic shows 215V:
215 / (10/215) = 4622 ohms.
Perhaps he uses a higher load resistance because, as he writes:
In other words, even though we can get less usable power at higher load resistances, our linearity improves (and therefore, total distortion decreases).
(That's a blanket statement, and as such, untrue--there's certainly a point beyond which you shouldn't increase the load resistance.)
Regardless, if the OT is too small to handle 10 watts, it will saturate even if it's close to the correct impedance.
May 8, 2010. 8:26 PMgmoon says:
Now I see you're using a PP output transformer...that could be the problem--as well as the size.
It doesn't seem like you should get 200mA of current @215V. That's a lot of current through a tiny OT.
Also, a Pa of 10 watts is probably a max of 5 or 6 watts of output in a single-ended topology. Fred's only expecting 1 or 1.5 watts...that's probably why he chose a 9.8K OT, vs. a lower load resistance.
Is this an "audiophile" project? Because the choice of OT (and the output) will effect the level of acceptable distortion... I fool with guitar amps generally, which is a different thing. And he's not letting the signal clip, either (of course, once it clips it's not measured as "legitimate wattage" anyway, according to the definition.) Are you pushing it too hard for clean output?
AES has an 8 watt, 5K:8 single-ended transformer for $14. Search for P-T31(their new webpage is all frames, so I can't just copy the link..) Actually, I like Edcor transformers, too. They are HUGE, and I think over-engineered (the wattage specs are conservative.)
May 9, 2010. 6:31 AMgmoon says:
When I built my SE amp I used a Hammond "universal" transformer; they're supposed to cover both SE and PP operation. Even though it was within the wattage specs, it was over-distorted--very little headroom.
I think both Steve and I are telling you the same thing--you can't use a PP transformer in a SE project.
Single-Ended amps conduct 100% of the current whether they are loud or silent. I.E., at quiescence or at maximum output the current through the transformer is the same. That's why SE are gapped, and always larger than PP transformers--there's a constant DC voltage on the transformer.
Before ripping out the transformer, you could add a NFB (negative feedback) loop, which will reduce distortion (it will reduce the output too, somewhat.) It's simple, and worth a try. Check out the Fender Champ 5E1, the NFB loop is the connection from the OT to the cathode of the second stage 12AX7--with the amount of feedback controlled by the 22K resistor (play with that value.)
One more thing--Fred's project is cool, but it's another one of those "oddball" tube projects. Lots to learn from it, but it's a compromise.
May 8, 2010. 2:35 PMsteveastrouk says:
What quiescent current's flowing through the transformer ? I'd guess at a saturation effect.
Steve
May 9, 2010. 4:52 AMsteveastrouk says:
I think you need a gapped core. I also think that the core is VERY small for the power output....I shall consult an expert and get back to you....
May 8, 2010. 12:01 PMRe-design says:
Can you give me a link to the schematic?  Without that it's just a guess.
But if the output trans is wrong that might shift the freq. response.
Are there tone controls?  If so you may have to adjust the caps there to shift the response to something you like more.  That's done with guitar amps many times.
Also, what kind of speakers are you using?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
