How can I join two or more small cables (e.g. bike shift or brake cables) to make a longer one?
I want to build a stool using two stages of a tensegrity tower (https://www.instructables.com/id/Desktop-Tensegrity-Tower).
I need a non stretchy line for the tension members. I was thinking bike cables because I think I can scrounge them for free.
Burf6 years ago
Use a steel cable splicer. They're available in a variety of sizes work very well and they are relatively chea.
i have solved this problem 2 ways. the first was soldering the 2 cables together. this looks cleaner, but bike cables don't like to solder very well and it's kind of a pain. the second, and easier way, is copper tubing. go to the store and buy the smallest diamater copper tubing you can find. insert both ends of the cable into the copper tube, and smash the hole thing with a pair of pliers. then add extra crimps at regular intervals with a pair of sidecutter pliers.
You could also solder the cables into the thin copper or brass tube.
caarntedd6 years ago
Make a loop in the endsto be joined, and loop one through the other or use a small turnbuckle to join and tension them. Close the loops with a cable clamp, or swage.
kevinhannan6 years ago
+1 what ork says
orksecurity6 years ago
I'd hook the ends of each into a screw tensioner, looping the ends back and clamping them to the cable somehow to form a loop. That would also let you adjust the tension, of course.
