How can I keep my bike handlebar grips in place?
8
answers
Answer it!
I never liked permanently modifying my stuff.
Standard bikeshop practice is this;
-Remove a grip.
-Spray a generous amount of clear laquer into the inside of the grip.
-Immediately slide the grip on; you only have seconds to do this and you do not want it stuck half-way.
-Repeat for the next grip.
-Leave to set for at least half an hour.
That should do it.
The solution was to remove the grips and thoroughly clean and dry them, as well as the bars. Refit the grips, (this was pretty tough sometimes) then fix them in place with steel tie wire. The wire was wrapped around the end of the grip closest to your thumb, and served to not only anchor the grip in place, but also to keep dirt and moisture out. Sometimes I also wrapped the other end if there was still any slight movement.
I wonder how this would go using an electrical wire tie or maybe a screw on hose clamp? A little tape over the sharp bits and away you go.
