How can I make LED tea lights remote control ON/OFF?
I want to be able to remotely turn off a bunch of cheap electric LED tea lights. I have a total of 15 in a room I want to be able to turn ON/OFF with an IR remote but dont have a clue how to start. They will be situated in votives around the room so they can not be connected together so I think I will need a circuit on each tea light. I have looked into buying units already made but they are way out of my price range for this project. Thanks so much for your help.
Visit Our Store »
Go Pro Today »
And I include how I would start designing a Votive IR switch
don't worry about the values because the start circuit was 9-12V.
The first pic responds to a 40Khz maybe someone knows or has measured
the TV remote or you can look it up, I don't remember back when I did.
As I said it is a start where I would begin ,
I really don't have the detailed answer.
You need to do some of your own work.
After all this site is an instructable site.
TI sells 3 Volt smd individual edge triggered flip-flops.
Here is a problem for you to work on. This block design will flip every time
a signal is detected. What happens if some votives don't see the signal
to turn on and you send again ( some will turn on others turn off )
How will you fix this ??
Read some of what was pointed out for you.
Learning is stretching the little gray cells,
Stretching can be a bit painful.
Eventually learning is fun.
A
and a 2 stste transmitter.
Study the IR Detector, the blue LED, the PICAXE and RGB mood.
Are you intending to use 3v smd FF to keep it small ?
IR presumably, would be the only IR in the room.
