How can I make a homebrew EEPROM programmer?
Hi everyone!  I have some EEPROMS I would like to burn (27C512, 27C256, 24C256).  I have a Parallax Propeller, a Z80, a 6502, and an Arduino Uno to help me make an EEPROM burner.  I know that EEPROM burners run $40+ commercially (even on EBAY!), so I would like to try building my own at home.  I have an abundant supply of 74XXXX chips at home, as well as a good supply of capacitors and resistors.
I don't have a Parallel Port on my computer, but I have a USB port as well as an RS232 to USB converter.  I'm running Windows XP and Ubuntu - Lucid Lynx 10.04, so if I need a specific OS to burn these EEPROMS, I have Windows and Linux.
I need an EEPROM burner that could  erase/burn the 27CXXX EEPROMS/EPROMS/PROMS.  I know through using the Propeller that I can write to the 24C256 through the Propeller, but could someone please help me in building a homebrew EEPROM burner?
Jul 10, 2011. 2:10 AMsteveastrouk says:
The old Intel 8052AH-BASIC included code to burn EPROMS (you have EPROMS NOT EEPROMS) The hardware consisted of a "high voltage" (OK, 12v) switch and a smalll relay if I remember right.
Writing code to burn Intel Hex is dead easy.
"Burning" means programming, not clearing - that's always called "erasing"
Steve
Jul 9, 2011. 9:13 PMMachinegeek says:
Have you looked at the Bus Pirate from DangerousPrototypes.com
It's open source so you could build it yourself or just buy one already assembled.
I think they sell the bare PCBs as well.
Jul 9, 2011. 10:35 PMiceng says:
so can you speak Zilog or Intel Z80 code and Mot 6502 code ?
Jul 10, 2011. 2:24 AMAndyGadget says:
That question brings back memories of my first real work experience where I was given the task of designing a 2708 / 2716 programmer interfacing to a Commodore PET computer via the IEEE-488 port.  That was around 1980.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
