3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How can I make a moped faster?
Apr 2, 2011. 12:22 AMtragicallyhip says:
Your Moped,like nearly all Asian model's use the GY6 4 stroker originally designed by Honda back in the 80's.Which is a good thing since go fast parts are everywhere,I have seen video's of these suckers going 80mph.
Visit 'scootertronics.com' for intake,exhaust and cylinder head go fast pieces,this is just one of many companies out there supplying after market goodies.
Just remember these machines are not designed to go fast,and a pot hole is like a sink hole when your riding on 10" tires.
Good Luck
Tragic
Apr 1, 2012. 7:52 PMthegreatkoua says:
You can make a moped go faster just drill the peacock hole bigger. It will burn more or waste more gas. but it does make you moped go faster or just have to buy a bigger cc engine.
Apr 16, 2011. 9:27 PMklandathu says:
Thats a scooter not a moped.
Apr 2, 2011. 12:08 AMrickharris says:
More than likely you can't easily.
Gear ration, engine power. weight, drag are the biggest factors.
Apr 2, 2011. 4:01 AMrickharris says:
The attached pictures are typically attempts to reduce drag NSU quickly held the moped speed record for many years
Apr 2, 2011. 1:09 AMlemonie says:
You can change: the air filter, carburetor, reed-valve, exhaust.
Any of these can increase the power output of the engine.
Go looking for things like this:
http://www.scootertronics.com/hipescpa.html
L
Apr 2, 2011. 12:17 AMcaarntedd says:
How fast can you make one now?
Apr 1, 2011. 7:21 PMVyger says:
Strap on some booster rockets.
Or attach a rope to a passing Porsche and hold on tight.
Apr 1, 2011. 5:09 PMseandogue says:
Lose weight, improve the performance of the motor, makes sure that the drivetrain is working as efficiently as possible, repack your wheel bearings, tune your brakes to ensure there's no ghosted drag...
Apr 1, 2011. 5:03 PMRe-design says:
Go down a steeper hill.
Apr 1, 2011. 4:48 PMfrollard says:
Add more power, reduce weight, reduce drag.
...specifically to answer your question, apply more force to it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
