loading
How can I make a power supply for cold cathode lights that would normally go into a computer power supply?
I'm looking to put some cold cathode tubes behind my flat screen LCD tv and my computer LCD. I was going to pick up the Dioder lights at IKEA until I saw they were $50 for a set of 4!!! Any ideas? Is there an instructable that I missed? Thanks all.
gmxx8 years ago
https://www.instructables.com/id/How-to-power-up-an-ATX-Power-Supply-without-a-PC/
Follow this instructable using a psu outside of a computer, and then plug your cold cathode lights in. you can get the psu out of any old computer, at your local electronics retailer or online. you wont need to get anything super fancy.
The cold cathode lights will probably need to be bought online.
Joaquin9 (author)  gmxx8 years ago
This is awesome! Just what I was looking for. I looked at some other more complicated ways of putting together an LED lighting strip but this seems to be the solution. Thanks!
gmxx Joaquin98 years ago
Your welcome.... now click the best answer button next to my name.... lol
I did :)
thank you!
just follow this link and build it the parts cost me less than ten dollars at radio shack https://www.instructables.com/id/Make_a_simple_12_volt_power_supply/#previewlink
110100101108 years ago
inverter from emergency lighting. go to trash yard and look for fluorescent light fixtures with extra module and pack of nicd batteries in them / electrical exit signs. get the module out and wire directly to the ccfl and power supply (instead of battery). give it lower voltage than the battery was. dont wire it to ac power (it should think there is power outage to light) inverter from flash camera (usually is quite dim). needs resistor to not overheat
lemonie8 years ago
You can do cheaper than IKEA
e.g.
http://www.google.co.uk/search?hl=en&q=led+lighting+strips&btnG=Search&meta=
Unless you've already got some lighting you're probably going to have to spend something on this.
L
