3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How can I make a simple MECHANICAL water pump (no electricity should be used)??
May 3, 2010. 7:07 PMkleinjahr says:
Not hard to build a pump at all. look up Ctsephon or Hero of Alexandria. If you've ever seen an old horse drawn fire pump that's it. Archimedes screw is simple, wrap a hose screw fashion around a frame, a barrel works well. put it at something less than 15 degrees from horizontal and turn it so the immersed end gulps up water.  A simple force pump can be made by joining several lengths of pipe with check valves. Use a larger diameter pipe as a guide, plunge the first pipe up and down until water comes out.
Apr 21, 2010. 9:03 PMeripe says:
This guy has a pretty nifty one:
http://myweb.cableone.net/bcanderson/Boatz/Bilgepump/Bilgepump.html
or you might want to check out this page
http://www.fao.org/docrep/010/ah810e/AH810E06.htm#6.2.3
I wonder if you could power a centrifugal type with a bicycle.
But the Money Maker is pretty hard to beat if you are looking for a pump at less than $40
http://other90.cooperhewitt.org/design/super-moneymaker-pump
Jan 16, 2010. 12:45 PMdrbill says:
Google 'Clack Valve'
Also there was a guy that put out an Ible He Made One.
Jan 11, 2010. 10:47 AMjosh says:
to move a volume of water quickly and efficiently there's always the treadle pump !
Oct 30, 2009. 6:18 AMsteveastrouk says:
There's always the force pump, which is a bicycle pump with some valves.
I think they'd be easier to build than the screw for an archimedean pump.
www.google.co.uk/imgres
Steve
Oct 30, 2009. 8:31 AMRe-design says:
There is just something about the archim. screw that I really like.  Someday maybe I'll figure that out and move on.
Oct 30, 2009. 11:21 AMsteveastrouk says:
I know what you mean - but I really don't fancy making the screw bit !
Steve
Oct 30, 2009. 6:17 AMorksecurity says:
Or water mill in reverse. Or piston pump. Or.... Websearch "simple pump"?
Oct 30, 2009. 5:53 AMRe-design says:
Archimedes screw on of the simplest water pumps to make.  Very easy to make the size you need and easy to run by mechanical means only.
Here's the link.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
