3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How can I make an easy power supply?
I want to make a really easy power supply that uses direct line voltage (120) using just a capacitor(WITHOUT a transformer).  I've seen the instructable where Tool Using Animal (http://www.instructables.com/id/LED-Lightbulb/) made one for LEDS. I measured it and got around 2 volts.  That was with a .47uf cap.  I want to get around 12 volts but I don't know how to get it without buying 20 different caps to see which one works.  Is there a formula? Thanks in advance for your help..
Dec 27, 2010. 11:21 AMlemonie says:
Notice that also uses a "1/4 watt 1kilo ohm resistor" - like others I don't think you should try this sort of thing.
L
Dec 27, 2010. 11:13 AMNachoMahma says:
.  I have to agree with the others on this one: you obviously don't know enough about electrical safety to be messing with mains voltage and/or an unisolated power supply.
.  Your best bet is to get a mains-to-~14V transformer, a rectifier bridge, and a 12V regulator.
Dec 27, 2010. 10:39 AMRe-design says:
Making a power supply like this to use in other than a totally shielded way is incredibly dangerous.
Any hobby power supply should include a transformer with separate primary and secondary windings.  Using wall power like this would become 120 volts a/c should the capacitor short out and they often short out.
A 14 volt transformer can be had for less than $10 or free if you scavenge a bit and is infinitely safer than what you propose.
With all due respect, I hope no one has the lack of common sense to give you any details.
Dec 27, 2010. 10:53 AMseandogue says:
+1
Dec 27, 2010. 10:45 AMsteveastrouk says:
A non-isolated power supply is not something suitable for hobbyist use: it is essentially at mains voltage and can easily be lethal.
Steve
+1
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
