How can I make my printer see the ink level as not empty, there is always more ink in the cartrage?
I saw the answer somewhere and can't find it again, so far I think there was some connections on the cartrage that could be shorted ,Anyone know how? disabledan sparky220@gmail.com
Siej1 month ago
Maybe you need one. save the following link to set up your printer. www.canon-mg3620-driver.com
NOGUNZ10 months ago
"Cartridge," not "cartrage." Correct spelling yields better results!
ronnie1111 months ago
I suppose that you made some adjustment making a continuing printer ink on your computer printer specifically. That's mostly the situation when you do this, the cartridge have their chips this is the medium for this to talk to the printer about the state of the cartridge like the ink level. That is ruined by setting up ciss (ongoing ink source system) on your computer printer since it the printer ink level will never be accurate with the amount of images the cartridge does. That is always occurring if you ask me after i buy Canon PIXMA MG2120
Alright so the appropriate response fluctuates extraordinarily relying upon the kind of cartridge you're attempting to refill. I have some involvement with Epson. There is a gadget that can be utilized to reset the chip on a few printers, yet there can likewise be an optional issue with a portion of the more current cartridges - a wet sensor, taken cover behind the chip. Find more about the atlantic cartridges
rehemenway3 years ago
Get a "People Friendly" printer, like a Brother printer, that uses toner cartridges that holds a lot more ink at a far cheaper price :-)
habdulraouf3 years ago
well , it happen to me with my Brother LC 40 cartridges . when I first bought it I recognised that it runs out of ink very fast. when I take off the cartridges I see amount of ink spilling inside it. so I never through it hopping it will be useful on a day. any how, I was staking for a printing job today and looking for a solution on the net but could not figure a good solution to my printer.. so I've took the C cartridge from the printer which was highlighted as no ink.. hit it on a tissue above the table for 10 times. inserting it inside the printer.. and the magic starts. the printer recognise the cartridge as low ink again .. but it makes it to print again.
Depends on the model of printer. Soldering a hole in the top of the cartridge and pouring some more in works for me.
castleink3 years ago
Check out the help section on Castle Ink - http://www.castleink.com/category/36/Printer-Help.html
msanabria5 years ago
Ok so the answer varies greatly depending on the type of cartridge you're trying to refill. I have some experience with Epson. There is a device that can be used to reset the chip on some printers, but there can also be a secondary issue with some of the newer cartridges - a wet sensor, hidden behind the chip. This is true of some Epson cartridges. This video might help, it shows the differences between 'older' and newer chipped cartridges and also the chip resetting device: http://www.youtube.com/watch?v=fB8QspjBbhk
Unfortunately you might be out of luck if you have a printer that uses one of the newer cartridges (like I am).
If you're using a knock-off brand that isn't working, you might want to contact the retailer to ask for a refund.
Ink Brother5 years ago
I assume that you made some modification specifically making a continuous ink on your printer. That is mostly the case when you do that, the cartridge have their chips that is the medium for it to communicate with the printer about the state of the cartridge including the ink level. This is ruined by installing ciss (continuous ink supply system) on your printer since it the ink level will not be accurate with the number of prints the cartridge did. This is always happening to me when i buy ink supplies online .
Your printer is OK. Try buying an original cartridge and i assure you that the ink level will then appear again. It will disappear again after installing ciss on that cartridge again.
fwjs288 years ago
well, what type of printer is it?....are you sure there not close to empty....and are you sure they are the correct drivers....
this happen to my mate printer, i'm not to sure it a software issue but more of a hardware issue.
It is a issue with the printers itself. There are some "resetting" tools and button combinations for some printerse. But we need the exact type of printer he has, because thats different not just from fabricator to fabricator, but from model to model.
toko13 wupme5 years ago
Hi,
I have a quite new Lexmark PRO205 printer.
I wonder if there is a way to reset just filled ink cartridge to full.
Everything seems the 'Lightbulb Conspiracy" is #$%^&* true.
Thanks in advance.
i had my ink cartridge refilled at one of those 'cartridge world' places. it always tell me its low/about to run out, even though the black ink has never looked low. was yours refilled as well?
Thats because the chip of the cadridge and the printer register the cadridge as empty. They have to be resettet for the printer to recognize ist as full.
el.lori6 years ago
LED ALADDIN Limited
All light sources in our houses or at work must give an appropriate amount of light depending on the type of activities we perform. While working on a task that requires medium concentration the illuminance in a room should be at least 300 lx. The desks and keyboards while working at a computer should be illuminated with about 500 lx and while performing tasks that require high precision and concentration the luminous flux density should be about 750 lx. For comparison the amount of light that is enough for relaxing and watching tv is about 20 lx. Under this value the human eye is not able to recognize the features of a face.
Examples of suggested illuminance in rooms
Living room
1.main lighting: 100-200 lx.
2.surface of a table for reading and writing: 300-500 lx.
3.dining table: 300-500 lx.
4.computer stand: 500-750 lx.
Kitchen
1.main lighting: 200-300 lx.
2.under shelf lighting: 500 lx.
Other rooms
1.hallways, stairs: 50-100 lx
2.bathroom and toilet: 300-500 lx
Other exemplary values
1.facial features recognition: 20lx.
2.sunny day: up to 10 000 lx.
Multifunctionality of lighting
While designing lighting in a house or flat it is important to keep in mind, that very often one room is used for many different kind of activities. For example a living room is a good place to relax and watch TV (where a subtle, slightly diffused light is most appropriate) but also for family meetings and meals for which the luminous flux density should be about 300-500 lx. This is why we should not limit the light sources to only one, but to few different lighting points that can work independently from each other.
Many sources of light in one room
Due to the fact that most of the rooms in our homes are used for different activities, it is suggested to use multiple independent lighting circuits. A very good solution, that is more and more popular in interior design, is diffuse lighting. Diffused light may be produced both by a reflection of light from a completely nonspecular surface and by using multiple small point light sources.
Energy efficient and environmentally friendly
While designing the lighting in a house it is good to choose light fixtures that can work with energy saving light sources. This environmentally friendly lighting not only helps to save money, but it is also shows our care about the environment.
Good quality light sources
We should always remember to choose good quality light sources. Very often a theoretically cheaper light source is actually more expensive because of its shorter lifetime and because its performance is much lower than stated by the manufacturer.
Contact LEDaladdin
LED Aladdin Limited
No.406 HongTeng Building,
No.392# Xihong Rd,Gulou.
Fuzhou,Fujian.
350002
China
Tel. : +86 591 6310 1956
Fax. : +86 591 2285 5952
E-Mail : info@LEDaladdin.com
WEB: http://www.ledaladdin.com/index.html
Some ink cartridges don't actually measure the amount of ink left, but instead count the number of times they have printed (ie. the # of dots of ink). This is interpreted by the printer and displayed as an ink level. Higher quality machines like photo printers will actually check the ink level. I tried refilling the cartridges on my printer, and they worked fine, except that the ink level stayed at empty on the display
11230168 years ago
Bash the printer with a bat.
Z..8 years ago
First of all my apologies; I don't know how to bring this copy/paste info to normal size.
I found this on a discussion site that was referring to a certain brand printer that has a built in facility (this was apparently proved) which says that ink needs replacing when it did not. It was designed to bring in after-market dollars!
I did this. It worked! The ink was more than half full! (Please don't ask for technical detail. I just followed the instructions like a trained parrot!).
You need to keep a check on when the ink has really run out though.
"THERE IS A PHOTO CELL TYPE SCANNER THAT SCANS THE INK CARTRIDGE AND IF YOU LOOK AT THE EMPTY CARTRIDGES YOU WILL SEE A MATRIX OF A REFLECTOR THAT TELLS THE MACHINE TO DISPLAY LOW INK AND THEN OUT OF INK.
WHAT I DID WAS PLACE A PIECE OF ELECTRICAL TAPE OVER THESE REFLECTORS AND WHALLA.....NO MORE REFLECTIONS AND NO MORE TROUBLES WITH THE MACHINE TELLIN ME THERE IS NO INK WHEN THERE REALLY IS INK...BE IT SMALL BUT STILL THERE. THE TAPE BLOCKS THE REFLECTION AND TRICKS THE MACHINE INTO THINKIN THERE IS PLENTY OF INK AS IF THE CARTRIDGE IS FULL WHEN IN FACT IS IS NEARLY EMPTY....OR IN THE CASE OF MY FAX MACHINE ...IS EMPTY.
NOW THE INK WILL RUN COMPLETELY OUT BEFORE I OBVIOUSLY NEED TO REPLACE/REFILL THE INK CARTRIDGES."
yokozuna8 years ago
I just saw the perfect answer to this about a week ago... only I don't recall exactly where for sure, possibly on the yahoo front page. It basically said ink cartridges normally don't "run out" but rather "dry up". It suggested using a small amount of household chemicals as a solvent to dissolve the ink again and make the cartridge usable. I haven't tried it myself, but it sounds like it's worth looking into (I would try rubbing alcohol, but there may be something that works better).
wupme yokozuna8 years ago
The problem is, for most printers if the cadridge ones tells the printer its empty, then its empty. No matter if you fill it again, or dissolve the dryed out ink. The chip says its empty. Thats been done by manufactures to prevent you from filling the inc cadridge again, they want you to buy it.
