loading
How can I make night vision goggles without theatrical gel sheets?
How can I make night vision goggles without sheets of red and congo blue theatrical gels? I can't get them where I live and I don't want to buy on Ebay.
thegeeke6 years ago
It sounds like you could just use colored plastic. Gels are expensive because they are designed to be used in extreme heat.
(I haven't spent a lot of time reading your comment, but I really think you could just use colored plastic.)
If you do need gels, look for a music store like guitar center or sam ash... they can usually get gels for you.
If you want to get them online, look at http://www.internetapollo.com/Products/Pages/Gel.aspx or http://www.allprosound.com/. I personally really like All Pro Sound.
iceng thegeeke6 years ago
Look through a gel and plastic before you commit.
thegeeke iceng6 years ago
I agree... like I said, I haven't looked at your project in detail, so I'm not sure weather or not you need a gel.
jduffy545 years ago
I have an instructable on how to. These are real IR night vision, not what Kipkay made, which just filter out most visable light.
iceng6 years ago
All video cameras ( PC type too ) are intensely sensitive to IR light,
so they regularly put an IR absorbing filter to block IR in front of the lens.
Just remove this filter and you have a night monocular detector.
Send the video image to any small monitor.
You can light your scene using deep IR LEDs ( 940 nm ).
Finally there is an image intensifier that can see images lit up by only star light
on a moonless cloudy night. The military uses that and it co$t$.
A
orksecurity6 years ago
There are a lot of ways to buy on line other than eBay. Theatrical gels can be mail-ordered from theatrical supply houses. The trick is going to be finding someone who will sell in small quantities.
I have no opinion on whether that approach works or not.
rickharris6 years ago
By far the easiest way is to use a video camera and some infrared LEDs even a standard digital camera will work with IR LEDs.
