How can I make this barrel organ idea?
14
answers
Answer it!
Impossible is an ugly word, forget it and never pronounce it again.
Why not use a washing machine barrel/drum and its bearings, it is all drilled for your needs, if you look for a salvaged front-feeded machine drum you may just find one that fits without too much work.
Do the pegs out of regular screws, washers and nuts, maybe you can find a special with a nice rouded tip or use lug nuts that would be kind to your metal rods.
Punch/drill a hole in your flat rods, put them on a good resonating wood box, cover them with a thick steel piece, pull a screw through it and you´re almost done.
Okay, now for my crazy-expensive version: Drill holds in the barrel for each rod, along with some support. Now attach the end of the rod to a servo mounted in the barrel. Attach the servo to a MicroController. Now you can program the servos to move the rods into striking distance on command. You can write a song in the software, load it up (or transfer over serial). Have a motor turn the barrel and you've got a music machine... Should only be about 160 servos + Microcontrollers + programming hardware... ;)
To make it look nicer, maybe use an old beer keg, and then Steampunk it.
