3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How can I melt a lot of snow quickly?
At work, I've got a mound of snow piled up about eight feet high and it's right over a staff member's parking spot.  The sun is helping to melt it and I began to shovel a little bit out each day, but I was wondering if there were any other handy tricks to melt it quickly.
I can't use fire and I don't have enough salt.
Any ideas?
Mar 5, 2010. 4:45 AMRe-design says:
If the temp is above freezing, spray it with water from a water hose.  As long as it can drain off before freezing it won't cause a problem and will melt the snow.
Feb 26, 2012. 12:34 PMmseba says:
it depends, anyways salt doesn't work that well .... if you have just enough sun you can spred it , put ash over it(because its a dark color) and cover it with a big transparent plastic foil..
the second solution is to drill a hole in a metal barrel almost at the top and make a fire underneath it then just put snow until the water melted starts to run over the hole at the top its smart to hook a hose to the hole to make the water drain away from the fire..
i think i will make a inscrutable with the last one because i will make it tomorrow
Feb 28, 2012. 10:35 AMmseba says:
yep dne it my snow was gone using the fire under the barrel method i still smel at smoke and it was slow but it worked ...
Mar 5, 2010. 10:49 AMLoneWolf says:
Flamethrower :)
Mar 8, 2010. 5:20 PMkcls says:
Most definitely :)
Mar 8, 2010. 6:14 PMLoneWolf says:
Yeah...........and then the Bazooka for the high drifts :)
Mar 9, 2010. 12:27 PMkcls says:
lol
Mar 5, 2010. 8:00 AMjeff-o says:
What's your budget?  Hire a snow removal contractor to haul it away.
Mar 4, 2010. 8:49 PMaaronscottaugustinhotmail.com says:
 Umm if there are no cars around throw peleted salt down you can buy a 40lbs  bag at your local home and improvement store most likely. its about $5 USD a bag.www.lowes.com/SearchCatalogDisplay
Mar 4, 2010. 6:30 PMkcls says:
Hair dryer, with a really long extension cord?
Mar 4, 2010. 6:18 PMdigitalbrad says:
spreading it out like you're doing helps a lot.  Maybe you can have car exhaust blow on it?  maybe wire up a stove element some how and just leave it ontop?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
