3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How can I morph a nearly 1/4 " aluminum disk into a cone?
Attached is a crude Paint drawing of what I am after (the cone doesn't have to have  that much of a "throat" on it, I just need it to be slightly funnel shaped.
I need to do this without "firing up" or heating the metal, and hopefully without marring the surface very much.
Any ideas?
Feb 19, 2010. 3:32 AMKryptonite says:
Get a pointy metal thing:        ^
and metal cylinder that has a slightly less than diameter of your disc:    | |
get a vice:        =
put it in this order:                       ----------
                                                        <disc>
And squeeze it.
I hope that made sense. Now bask in the glory of my terrible ASCII depictions. I'm sorry for any confusion / hurting of eyes.
Feb 22, 2010. 9:51 PMKryptonite says:
It's still cool where you are, right? Gallium in a mold. Use that.
Or Bismuth. Alot of the suitable alloys such as "field's alloy" or "Wood's alloy" is quite hard to acquire.
Feb 22, 2010. 9:52 PMKryptonite says:
*doh*
are*
May 10, 2010. 1:52 AMKryptonite says:
I was thinking of you using it as a sort of press / mould / thing.
Thanks for the best answer!
Feb 17, 2010. 7:25 AMRe-design says:
THis is typically done on a lathe using a wooden "paddle" to work the metal down against a wooden form that is the shape you want to end up with.  Most of the pieces I've seen are made out of aluminum.  I don't know how easy or hard it would be to spin other metals.
Here's a detail on how to do it.
And here's a sample of some shapes that can be made.
Mar 19, 2011. 11:43 AMbikerbob2005 says:
find a brass bushing the right shape of the impression put a bolt through it use a socket wrench as a receiver 1/4" bolt grade 8 snaps at about 50 foot/pounds of Torque 3/8" maybe 100 . or big C-clamp and a ball bearing same socket wrench receiver ? I use that to press out u-joints on trucks.also need to lube the die, electrical wire lube works ok http://www.jhlarson.com/ind_tables/lube/lube_table.htm , or beeswax
Feb 17, 2010. 11:28 AMjeff-o says:
If the disc is half an inch thick, you'll need a few dozen tons of pressure to get that shape.
If it's half an inch across and relatively thin, you could "machine" a die out of hardwood and use a bench vice as a press.
Feb 17, 2010. 12:59 PMjeff-o says:
Ah, at 1/4" thick, without wanting to mar the surface too much, your best choice is a big, heavy press.  You could use a lathe and draw it out, but that would indeed mar the surface.  You'd have to polish it afterward.
I suggest calling some small machine shops in your area to find out if they can do it.  I doubt this is something you can do at home, without the right equipment.
Feb 18, 2010. 5:34 AMjeff-o says:
That would imply that there is a different material plating the aluminum - is that true?
Feb 18, 2010. 10:39 AMjeff-o says:
Ah, well why didn't you say so!  OK, so you want to force a hard drive platter into a cone or funnel shape.
A press is the only way to do it, and that will depend on what alloy the aluminum is.  There's a chance it will be too brittle to force it into any shape.
Do you have any other platters that you don't mind sacrificing?  What happens if you jam one in a vice and try to bend a radius into it?
Feb 17, 2010. 12:17 PMsteveastrouk says:
...if its half an inch thick, you'd just turn it in a lathe.
Steve
Feb 17, 2010. 7:39 AMsteveastrouk says:
If the dimple isn't VERY deep, go to your nearest sheet metal fab shop and ask for some of the punch outs from their flypress - a manual fly-press die has a locating tit which is engaged in a centre punch mark on your job, but which then gets pushed out in the waste into JUST the shape you want.
If you have the brass already, they may be quite happy to dunk a few holes in your sheet.
If you want a deeper cone, epoxy a few washers in the centre of the intended disk, punch it, boil the brass in water, and the epoxied bits should fall out.
Feb 17, 2010. 12:52 PMsteveastrouk says:
Nothing will not mar the surface...I think you'll have to re-polish what ever. Spinning is the obvious method - a wood working lathe is a good way to do it, but it takes a heck of a lever arm to do it. Anneal the aluminium first.
Feb 18, 2010. 1:30 AMsteveastrouk says:
You're stuffed then, it will not be possible to form that without marring the surface.
Why can't you re-polish the metal ? We do it all the time at work.
Steve
Feb 18, 2010. 9:09 AMsteveastrouk says:
The platter is made of aluminium, it can be repolished. There ain't no way you can avoid marking it.
Feb 17, 2010. 6:02 PMRe-design says:
You could use a shaped charge, but you'd better have a few to practice on since you'll probably ruin/loose a few before getting it right.
Feb 17, 2010. 11:20 AMlemonie says:
At ~half an inch, you'll need some force, a press would be the sort of thing. Otherwise whacking it with a big hammer I suppose.
Could you drive a car over it?
L
Feb 17, 2010. 12:29 PMlemonie says:
Ah different.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
