How can I re-align the screen on a TI-85?
The LCD seems to be calibrated 4 pixels off. When anything is entered into the base screen, the left four pixels are off the display, leaving the fifth column of the character to be nudged up against the left side of the display. When I graph something, however, the display is centered. Any ideas what could be causing this? A second "Reset All" didn't help. I'm a TI-83 user, so I'm not familiar with the TI-85 interface.
5
answers
Answer it!
Already did that. Thanks for the suggestion, though.
You reset the memory backup. Did you try doing this several times. It may be that it just didn't come up right the first time.
You might try joining a calculator forum. I'll bet they could get you the answer you need right away. Like this one.
Nice calculator for a buck if you can get the screen adjusted and there is probably a way to set that if you can find the service code.
