How can I repair/replace an arcing flyback transformer?
answers
Answer it!
1. scrape away the burnt carbonized area. Repair any broken foil-circuit-traces. This may fix it.
2. If arcing still occurs, then you may need to paint the area with "high voltage "paint" or "dope". Look on ebay for brush-on products for electronics technicians. Wait about 12 hours for paint to dry before turning tv back ON for test.
If the arcing is just an UNSOLDERED or broken solder point, you are in LUCK. This is a VERY COMMON problem in many tv's. Just clean the loose solder connection with a SMALL wire brush or sharp knife by scratching the blackened burnt stuff OFF of the terminal. Then re-solder the connection. Be sure to use PLENTY of heat to flow the solder real smooth. That will fix it!
If the transformer is arcing internally, I suppose it might be the HT lead that's at fault, so try changing that.
