How can I speed up my PowerMac G5?
Dual 1.8GHz PowerPC G5 processors
RAM maxed out at 4GB
1 TB and 500 GB hard drives installed
DVD burner
Mac OS X 10.5.8 (the last version that will run on PPC)
11
answers
Answer it!
1. Reinstall OS X
2. Upgrade the Ram or get an SSD
3. Buy Clean My Mac (http://www.macupdate.com/app/mac/30017/cleanmymac)
4. Repair Desk Permissions (That's in Disk Utility)
The cost is not as high as they used to be and if you are planning to upgrade to a newer machine in future, then you can re use the SSD... that way it won't be an over capitalization!
A 40GB Pro or 50GB Pro RE OWC ssd hard drives are $90-150 and the performance increase would be tremendous.
Naturally, you'll have to use the ssd hdd as the boot drive and a second drive to store data/apps etc...
If you like, I'll send you a feed back on the general results, once I use it a bit longer.
So far, boot up is crazy fast.. :-)
If you haven't done so since 2003, (I do so about every two years for all the house's computers,) you will be *very* surprised at the speed increase.
It was faster when you first got it, right? So why not put it to that same state?
Bottom line: GET A PC! (Windows 7 is pretty decent)
If you have external storage, if all else fails or is of little help, save the things you want to keep and do a clean install of the OS.
