loading
How can I turn an air conditioner on/off without remote.
How can I can I modify an air conditioner so that it can be turned on/off without the remote as soon as I turn on the power switch? I however want to use the remote to regulate the temperature.?
SamK1413 months ago
how do I get to set Hisense indoor units to auto restart when there is a blackout and the lights come back and I am not around to put them back on. ''server room'' VERY CRITICAL. HELP! HELP!
No power button on the indoor units. Just the remote
ShwetaS208 months ago
i have azure ac i cant find button in ac to turn on without remote. Plz help
juliog3811 months ago
Im trying to reset my remote and cant exactly locate what button to push. There is a word "reset" over the batteries section with 2 silver dots. Pressing them does nothing. Any help?
AlexS442 juliog389 months ago
Hello. Try to touch both with a cable to make contact with each othe. Good luck!
PavanA109 months ago
wow. super solution. @hendrosutono comment worked like a magic.
Thanks a lot !
open the air filter cover(front panel) on your air conditioner... usually you will find a small button to switch on... it's small spring switch, push it ones it's on, push again then it's off.... you can replace this switch with relay... now you have it...
have a nice experiment...
amazing and sure enough it worked!!! Thanks @hendrosutono
Thanks a Lot Man
I had a great experience...i was very disappointed when my AC remote was out of order
but you helped me to solve this problem in an eye blink...
SmarthV10 months ago
how to change the temperature in voltas ac without remote.....please tell me..! ?
SasidharanT11 months ago
HOW CAN I TURN MY AC ON WITHOUT REMOTE. AC VOLTAS 3* 1.5TON
I OWN A VOLTAS AC 3* 1.5TON. THE REMOTE IS NOT WORKING AT THE MOMENT. HOW TO TURN ON THE AC WITHOUT REMOTE.PLEASE INSTRUCT.
sirih411 months ago
i have a godrej smart ac. Where is emergency remote switch after opening the front panel
SamW261 year ago
how to manually turn on/off for this type of aircon.. please help...
hendrosutono is a genius. All hail hendrosutono! you are the master , you are divine!!!
lemonie7 years ago
How remote? Do you want to save your self the effort of getting off the couch, or do you want to switch it on half an hour before you get home? L
cprompt7 (author)  lemonie7 years ago
I have built a control circuit for the air conditioner that uses a relay to supply power to the air conditioner. I do not want to have to use the remote to switch it on again I may not always be in the room.
So some kind of radio device with a short range I guess? I'll think - off to work. L
