How can I get a fly back transformer from a ionic air purifier to work?
I took apart a ionic purifier and i haven't cut many wires(I needed the switch.), but i need help using it as a hv supply.
There's four different wires red, black, yellow, and white and i need to know witch ones to connect to get it to work. I'll have pics later.
UPDATE: Now I have pics.
P.S. It worked before I took it apart.
Visit Our Store »
Go Pro Today »
it should go directly to some of the pins on the flyback, that would be the internal power IN, or internal primary.
The ground is easy enough to find as it is likely directly connected to the power supply negative.
The flyback HV wire is likely the thickest one comming out of the top.
however, it has an external ferrite, so you can probably wind a new primary on, it just takes like 5-10 windings of any old insulated wire.
If you have the means, run the thing and check the frequency and pwm it runs at, and then just build an oscillator circuit which produces the same output, or just build the circuit the mad scientist recomended. i have, and it works great.
follow the guide on that site , it will work the same
http://uzzors2k.4hv.org/index.php?page=flybacktransformerdrivers
I will also note you spelt Nicola wrong it is spelt Nikola.
and i would have no clue if it is on the flyback.
