3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How can I use a stepper motor that has no markings on it? (voltage, amps, rotation degrees) Just model numbers
I pulled 2 stepper motors out of a old printer. They look the same but there are no markings on them. Only one red and 3 white wires. I don't have them with me this week, but how could I test them over the weekend?
Nov 25, 2010. 2:24 PMmauad says:
It is an old thread, but as I'm sure there are plenty of EM-462/3 units dusting on the shelves, I will post some info.
The measures are:
EM-462 Bipolar Stepper
Coil resistance: 9.2 Ohms
Coil wire diameter: 0.28 +/- 0.02 mm
EM-463 Bipolar Stepper
Coil resistance: 6.1 Ohms
Using alexander.m's prescription (scroll to find the post), and using 0.26 mm as the reference diameter, one have 0.26 mm = 0.010 in, multiplied by 100 will give exactly 1.0 A as the current rating.
As soon as I drive them, I will post some results.
Nov 7, 2011. 7:27 AMpiratus says:
nice !! can you help me with his ; i wanna make them run with pic 16f84 , can you help me with this ?! thanks !!!!
Mar 17, 2009. 1:44 AMtiar says:
wiring diagram and driver motor for atmega 8535, please your send to my email?????
Mar 17, 2009. 1:41 AMtiar says:
mau tanya untuk diagram wiring ke atmega 8535 dan skalian driver motornya ada ndak? klo ada tolong kirim ke email saya ya tolooooong banget.
Feb 4, 2009. 7:00 PMalexander.m says:
First you need to know how to weir it, for instruction on that go to http://www.piclist.com/techref/io/stepper/wires.htm
To find the rated amperage you would need to take it apart then use a micrometer or Caliper to find the coil weir diameter (note: a ruler is not accurate enough) once you have the weir diameter change the measurement to inches in Decimal Value then multiply it by 100 then you have the amp rating. To find the voltage you need a ohm meter to find the ohm value then multiply ohms by the amps to find the volts rating. to find the rotation degrees then you need a controller to test this.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
