loading
How can I using a MAME Joystick (Happ Joystick) with a reverse polarity motor?
I'm trying to use a Happ Joystick to control 2 reverse polarity motors. (But for this will just talk about one motor) If the joystick is pointing up the motor should go clockwise (+ -) If the joystick is pointing down the motor should go counter-clockwise (- +)I would like to use the Happ Controller because it's an 8-way joystick. Because of the happ joystick is meant to work, I know I need some sort of realy somewhere, I just don't know where. This will be connected to a 18 or 12 volt DC power supply.
This is something very similar as the Simple wired 2 motor control joystick. But I'm looking for something a little more larger, robust, and can handle abuse.
Thanks for any help.
NateMac (author) 7 years ago
Ran into a slight problem when I went to test the motor with the Potentiometer. The motor worked when tested but it fried the potentiometer. I used a 12v power supply, and a 10k-Ohm Linear-Taper Potent 500VDC 0.5watts, soon the powers supply will be changed out to 18v, what kinda of potentiometer do I need to use?
Thanks
Heres the current box, still waiting for the joystick to ship.
NateMac (author)  NateMac7 years ago
This is the power supply.
VM 80W18 - 18V DC AND 4.4 AMP SWITCHING AC TO DC POWER SUPPLY
  • Input: 100 - 240V, AC 1.6 AMP, 47Hz to 63Hz
  • Output: 18V, DC
  • Maximum load: Can be used for 0mA to 4400mA or 4.4 Amp.
  • With Changeable Polarity
Well here is the physical Wiring Diagram. Tomorrow I will start to put in all together.
Try this: Only one relay is on when you move the stick.
You'll need 2 relays, wired like this, per motor:
The diode bridge is there for noise proofing, as is the 100 Ohm resistor and 0.1uF capacitor. The motor will arc less if you add the bridge
NateMac (author)  steveastrouk7 years ago
What type of Relays would I use. From what I understand I need something like a DPDT relay. I just don't know how to wire a joystick like this in. Is there a type of relay that can send + & - through once a power signal is connected? The relays that have 30,85,86,87 on them, will that do it?
You need "DT" for sure, but SP or DP will work just fine.
What I've drawn in the circuit I've given you will do what you exactly what you want. You can add "trimmings" that will make sure you can't drive the thing through the stops of your pan/tilt mechanism that I can add for you.
What are the motors rated at current wise, and where in the world are you  ? If I know both, I can suggest some relays.
Steve
I'm out in the suburbs of Chicago.
I'm actually cheating with the motors. I'm using Universal Car Power Window motors from a conversion kit. All this device is, is a motor attached to a belt that connects to your manual window crank, kinda cheezy for a car (umm but I did use them) But they work perfect for this.
This is the window diagram from the manual.
Pretty chunky motors. I'm going to guess at at least 5 amps a piece. Radio Shack lists suitable ones, but automotive ones would be ideal. Try a Napa or Pepboys near you - I tried their websites, but they don't like selling "generic" relays. You MUST get double throw relays.
Steve
I JUST got back from "The Shack" (they are re-labeling I got the whole story) and picked up a DPDT Plug-In Relay
     1_____      _____2
     3-->/<-|      |->\<---4
     5_/                   \__6
 7-------------#--------------8
lemonie7 years ago
Do you understand what they were doing in the instructable and how the wiring is supposed to work?
What type of motor(s) do you want to drive (like how much power), and does it really need to be joystick controlled or would one switch do you instead?
L
NateMac (author)  lemonie7 years ago
It's meant to Pan and Tilt a Camera Rig. I wanted to use a 18v dc power supply so I can place a variable resistor to change the speed of the motors with another control.  So one hand would be on the joystick and one hand would be on a nob to change the speed(voltage).
The wiring diagram I came up with always will send a negative or positive to the motors which just wont work.
lemonie NateMac7 years ago
Between yourself and steve I'm sure you'll get this done. Please publish an Instructable when you do.
L
From beginning to end for sure!
