loading
How can i make a voltage or charge amplifier for a piezoelectric sensor ? what do i need to know ?
iceng4 years ago
You need to understand a piezo has more output range then any op-amp.
To use a piezo always add a peak limit and the natural negative protection.
If you can not determine your high piezo output before-hand there
is the technical gain amplifier selection on the fly with its attendant
resolution losses.
A charge coulomb integrating amplifier collector can be useful.
Strain gauges are proper more reliable approach to instrumentation.
A
To work out the performance, you need to specify the load you are going to apply, in terms of microstrain.
It could be 200V.
Take a look for "charge amplifier circuits"
nobykobe (author)  steveastrouk4 years ago
thanks for the fast response
The data sheet you posted has a block diagram of the signal amp. All you need is an Op-amp, resistor and capacitor and your all set. According to the diagram in the data sheet anyway.
Here is some great information on Op-amps that should help you figure out what you need.
http://www.talkingelectronics.com/projects/OP-AMP/OP-AMP-1.html
nobykobe (author)  mpilchfamily4 years ago
I want to know , how much voltage does the piezoelectric sensor generate so i can determine how to design the amplifier
Thanks
