How can i record better quality music with Audacity?
8
answers
Answer it!
You cans elect the recording quality level in the Audacity preferences.
To get some idea of the resulting sound quality start with a known good recording. You can copy and paste MP3's etc into audacity from Cd's
Now, a good mic is not necessarily an expensive one. You can get a fairly inexpensive one at Walmart. It is a Phillips brand for less than $20 US. It is a dynamic mic which is key to this setup.
Next is a preamp. After pricing analog preamps at music stores (YIKES!), I decided that I could design and build something much better and infinitely less expensive. Find my design at the Nuts n Volts Forum, 5th post from the bottom. This is a stereo preamp that takes advantage of the stereo LINE-IN input on the computer. This one makes the 3rd "preamp" available. The other 2 are a Behringer mixer and a Radio Shack mixer. Of the 3, this home built is the most quiet in reference to noise. Since it is stereo, you can use 2 mics and record both your guitar and your singing.
As for Audacity, make sure you have your source set to LINE-IN, and adjust the levels so that they are below the red. You can always pull the levels up after recording, but you will have a very hard time cleaning up the distortion caused by a "hot" signal. Also check your settings to see if the sample rate is set to at least 44.1kHz and the bitrate is 16 bit. That is CD quality and probably the max your computer can do.
Now take some time and look at the related links (to the right->). Once you have read through them and gathered up what you need, you should be on the path to making your own really clean recordings.
From what you have described in your follow up post, you are using a patch cord from the guitar into an adapter into the camera. Have you verified the quality of the connections? Is the cord good? Is the adapter good? Many times you'll find problems are with the wires or connectors. It might even be the connector on the guitar or the camera.
If you cannot get rid of the noise, your best bet is just to record the audio on the computer and use just the video from the camera. You can sync it up in editing.
Good luck!
Qa
http://www.google.com/products/catalog?hl=en&safe=off&client=firefox-a&hs=6ka&rls=org.mozilla:en-US:official&biw=1280&bih=675&q=usb+audio+interface+1/4%22&um=1&ie=UTF-8&cid=11668306216188569481&ei=OEFPTfCLOMqs8Aam5_GmDg&sa=X&oi=product_catalog_result&ct=result&resnum=2&ved=0CH8Q8wIwAQ#
... you should have better sound quality.
Thinking aloud,
Qa
