3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How can we reverse the chemical reaction of a lead acid battery without the addition of energy? Just adding chems.
http://hyperphysics.phy-astr.gsu.edu/Hbase/electric/leadacid.html shows the forward and backward chemical reactions.
1 answer
Feb 25, 2009. 4:46 PMS1L3N7 SWAT says:
While it may be possible to reverse the reaction in a lead acid battery using chemicals it is not a wise thing to do. You would have to open the case of the battery which is very dangerous. Car batteries build up internal pressure, and attempting to pry one open will result in sulfuric acid being sprayed out onto the unlucky individual with the pry bar in hand. Your best bet (if you need do do so at all) is use something like this:
http://www.instructables.com/id/Desulfator_for_12V_Car_Batteries_in_an_Altoids_Ti/
It will do what you want, with out the risk of melting you skin off.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
