How can you differentiate between delay commands in the same program?
I completed the last RGB program but I really didn't understand the commands. So I tried mixing the other two set ups and this is wwhat I got . (see video) Any tips to make it work better?
bekathwia7 months ago
I can't see your video but can you describe the behavior and show us your code modifications?
carlos-leal (author)  bekathwia7 months ago
Here is the code:
This example code is in the public domain.
int led = 9; // the PWM pin the LED is attached to
int led2 = 13;
int brightness = 0; // how bright the LED is
int fadeAmount = 5; // how many points to fade the LED by
// the setup routine runs once when you press reset:
void setup() {
// declare pin 9 to be an output:
pinMode(led, OUTPUT);
pinMode(led2, OUTPUT);
// the loop routine runs over and over again forever:
void loop() {
// set the brightness of pin 9:
analogWrite(led, brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness <= 0 || brightness >= 255) {
fadeAmount = -fadeAmount;
{delay(10);}
{ digitalWrite(led2, HIGH); // turn the LED on (HIGH is the voltage level)
delay(100); // wait for a second
digitalWrite(led2, LOW); // turn the LED off by making the voltage LOW
// wait for 30 milliseconds to see the dimming effect
