3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How can you fix a broken logic board (for ipod Video 5th gen)? PLEASE HELP! :'(?
I really need help. This is the 2nd iPod that had it's logic board effed up.
I don't wanna spend money, I just want it fixed.
Or if you guys want to send me an ipod or ipods or replacement parts.
PLEASE HELP, IT WILL MEAN A LOT!!!
May 1, 2009. 6:20 PMdombeef says:
So what is hapening with the board is it not turning on?
Mar 11, 2012. 8:05 AMssmathur says:
Hi There,
I'm having the same problem. My iPod (video) 30 GB when connected to either Windows XP or 7 charges but does not show connected.
Did you manage to find a solution for it?
Thanks.
Mar 24, 2012. 1:23 AMssmathur says:
Anyone! Need help with this problem.
May 2, 2009. 3:02 PMdombeef says:
OK well then... Do you have a mac or pc?
May 3, 2009. 12:10 PMdombeef says:
OK well then do you have the latest verson?
May 6, 2009. 1:46 PMdombeef says:
I mean on the computer
Sep 17, 2011. 6:09 PMkevinp1133 says:
I have seen this problem a few times. If it shows in "my computer", but not itunes format it and it should go into recovery mode. Also try manually putting it into disk mode. Also try a fire-wire sync cable if you can find one. But if none of that works, what sometimes happens is that the pins on the dock connector get pushed out.
If you take the cover off you can see. IF this is the case you could push them back easily, but they often come back out as soon as you plug it back in, so I recommend replacing the connector. You could trying glueing the pins in place but I am not sure how well that would work. Hope that helps.
Aug 12, 2009. 7:08 PMqwertyboy says:
i know this is quite old, and you dont want to spend money, but here is a site that sells iPod replacement parts. iFixit also, they have instructions on how to fix it
good luck ;)
Jul 29, 2009. 11:17 AMalienwear says:
Try it with someone else's computer and see if it will connect then. Try a different cable too.
Jul 6, 2009. 4:04 AMcecato says:
I have the same problema. And I have bought operation system in last version (mac and windows xp). Hi dombeef, what is your sugestion?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
