How can you use an LED strip along with a sound sensor?
I have a sound sensor and an LED strip, i can get a single LED to light up with the sound sensor (whenever i snap my fingers or make noise) but when i hook up the LED strip in place of the single LED, it doesnt work.
If i hook up the LED strip directly to my Arduino UNO to 5v and ground the strip works. The problem is that i need the LED strip to be hooked up to a digital pin on the Arduino instead of directly to the power for the sound sensor to work with it.
I would really appreciate any help!
Jan 26, 2013. 12:15 PMsteveastrouk says:
Tell me EXACTLY where you got what you got OR do a very good, hi res picture of one cell of the strip. See if you can read the chip number - the last strip I used used the WS062 series.
Jan 24, 2013. 8:39 AMsteveastrouk says:
Those LED strips take an amp per metre to light up. Your batteries will last for a couple of minutes on a roll of strip !
Steve
Jan 23, 2013. 11:39 PMsteveastrouk says:
You realise that that LED strip needs a load of software running on the Arduino to make it do ANYTHING don't you ?
Jan 23, 2013. 11:47 PMiceng says:
+1
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
