How come when I connect my psp go to a usb charger, it thinks the charger is a computer, and tries to enter "USB mode"?
5
answers
Answer it!
If the charger isn't being properly recognized by the PSP, it may see it as a generic device - or in this case, a mass storage device. The simplest solution is to modify the charging cable so that the two data lines are crippled, thereby supplying the PSP with power and no data to communicate. On the other hand, the charger will become a dumb device and continuously throw charge to the PSP, so if the PSP isn't designed to automatically sense the battery and stop charging you may run the risk of overcharging the battery.
Personally, I would take the charger back and get one specifically designed for the PSP - not only will you prevent frying the battery, but you also won't run the risk of voiding the warranty.
L
my psp2k (the go is probably different, being more cloud-centric) needs to be manually put into usb mode (otherwise it will just charge and act normally). The go probably has an option to turn this behaviour on or off.
