How could I connect an FPV camera to an SD card before transmission to a display?
Hi everyone, I'm pretty new to RC and I'm now looking at getting some FPV gear (camera - HS1177, transmitter - ImmersionRC 25mW 5.8GHz, receiver and display). I'd also really like to record my flights which would usually mean having a second camera on board (but I don't have the space) or recording the transmitted video (but transmission can introduce noise) so I would like to put an SD card in parallel to the transmitter. I imagine that if it is possible it's more complicated than what I've drawn but I was hoping for something along those lines.
Thanks in advance for any help that you could give me :)
Picture of How could I connect an FPV camera to an SD card before transmission to a display?
Andycb93 (author) 2 years ago
Thanks for the responses, there are a couple of options available but I have decided to just use a ground based recorder as it is easier to implement.
LisanB2 years ago
ORDER SAFE AND DISCREET
➽➽PAIN KILLERS,
➽➽MEDICAL MARIJUANA,
➽➽Act. LEAN,
➽➽ BUDS & SEEDS for PAIN RELIEF PILLS & TREATMENTS.
➽➽➽➽ For more info Text (505) 807-7504, lisanblakeretailshop@gmail.com.
We sefely and securely deliver all sorts of generic medication, marijane and some sipp Nationwide at very good prices. No prescribtions Needed ➽➽ .Legit , verified and reputed plug.Available in the U.S, CANADA , Australia and the UK.➽➽ ➽➽ For more info Text (505) 807-7504, lisanblakeretailshop@gmail.com , thank you.➽➽➽➽➽➽➽DFSDGGFG
A second receiver connected to a recording device is all you need. That way you don't have to have additional hardware weighing down your quad.
+1
kmossman2 years ago
While capturing the video on-board would give a better image [capture], keep in mind the impact on weight and especially battery drain. Depending on the flights duration, you may need to control the start/stop, resolution, fps as the SD card has a limit on space [and data transfer rate]. Easier to control those at the 'base station'.
rickharris2 years ago
http:// www.flitetest,com
may help they have a lot of details on RC FPV
You need extra hardware or a camera that supports what you need.
The cam provides a video signal that the transceiver uses.
You need to add the hardware to capture that stream and save it on the SD.
