3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How did the wind powered generators work that were made for African primitives using a vibrating vertical strip.?
There was a great TV bit on the amazing benefits to some grasS hut dwelling natives of having a one watt battery powered light in the evening.  Reduced the birth rate by a third!   The generator was powered by a vertical strip of something flexible held at each end beside the hut.  The wind caused the strip to rapidly rotate back and forth at its center.  A magnet(s?) place at its midpoint fluttered rapidly back and forth in front of a coil to generate current to be stored in a small wet cell.  The wet cell was carried into the hut at night, attached to a one watt LED and voila!  It change their lives.  They could READ in their spare time.   WHO HAS ANY IDEA OF HOW I COULD MAKE SUCH A GENERATOR??
Oct 17, 2010. 3:32 PMNachoMahma says:
.  Searching for "ribbon wind generator" or "WindBelt" should get you started in the right direction.
Oct 18, 2010. 5:51 AMsteveastrouk says:
Wow. And he calls the guys that can "throw" one of these together from bits "primitives". They knock us out for ingenuity.
Steve
Oct 18, 2010. 1:29 PMlemonie says:
"African primitives" is an interesting combination of words, is that a foreign-translation or just "old"?
L
Oct 17, 2010. 3:27 PMsteveastrouk says:
Seems to me these aren't "primitives" if they know how to make one and you don't.
Steve
Oct 18, 2010. 5:03 AMseandogue says:
Did they build it or did someone build it for them?
Oct 17, 2010. 4:01 PMNachoMahma says:
. Best Answer
Oct 17, 2010. 9:35 PMaeray says:
Seconded.
Oct 17, 2010. 5:07 PMfrollard says:
Long story short it works on the harmonic resonance of the plastic strip in the middle -- much like when you make a kazoo out of a blade of grass in your hands, or the tacoma narrows bridge -- the strip tilts one way, then it broadsides the wind and flaps the other way. Tada, resonance.
Attach a magnet to the strip at a 'sweet spot' where it will extract energy but not stall the vibration, and you have most of a generator -- at least the moving magnetic field part.
Put a coil in the magnetic field, and you're generating low power AC. Complexity? Almost none. Bill of materials -- strips of plastic, magnet, coil, charger circuit -- much simpler than manufacturing rotary generators.
Oct 17, 2010. 3:48 PMHarveyH44 says:
They aren't 'primitives', just economically challenged. Maybe we could trade presidents for a couple of years... Guess that wouldn't help them much.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
