How difficult is it to Increase the intensity of a plasma ball?
I just bought a cheap USB (5v) plasma ball.
Quite frankly, the intensity of the streams is pathetic. You can barely see it when the lights are on.
I wanted to use it for a decorative project, but need to increase the intensity of the streams.
Would increasing the voltage (say from 5v to 12v) work? Or is it more complicated than that?
I can do basic electronics, but mostly just simple stuff following circuit diagrams etc.
Picture of How difficult is it to Increase the intensity of a plasma ball?
glitvjaks2 years ago
I realize that this is an ancient thread, but here's my 2 cents anyways.
I have a plasma lamp that takes 12v DC. I've hooked it up to a variable voltage power supply and tested it at 15 and 18 volts. It didn't burn, break, release the magic smoke or anything - it just got brighter with increased voltage.
master key5 years ago
i think usb 2.0 provides 500 MA of power
shobley6 years ago
You could increase either the voltage or the current.
In a traditional Tesla coil design increasing the input current has a dramatic effect on the length and brightness of the streamers.
There could be current limitiing going on with
(a) The usb port
(b) More likely a limitiing resistor somewhere in the circuit.
This will involve cracking the unit open and having a good old poke around with a meter and scope. Placing a variable resistor in place of the current limiting resistor would be a good way to determine the maximum value. (This is why I always buy 2 of anything - one to test to destruction, and the other for best)
However - it's the current that'll kill you, not the voltage - so I would be careful you don't start pushing the plasma ball into the "dangerous" category.
Re-design7 years ago
If you're willing to sacrifice your plasma ball you could try hooking it to a variable d/c source and testing.
Whether or not it works depends on how it was designed. If the mfg. just took some 9 or 12 volt globes and figured out that they would still barely work on 5 volts and did nothing else you might be in luck.
If they designed a unit to work on 5 volts then increasing the voltage will bring an end to the operation.
Your other option is to gut the circuit and build a stronger, better 12 volt system.  THe hare part of the globe is the globe and electrode itself and making it look good.  The circuit itself is fairly simple.
