loading
How do I Open an OralB electric toothbrush?
I have an OralB Vitality Toothbrush, & I think that there is a lose connection inside. It usually doesn't work, but If I shake it, it sometimes switches on. This leads me to believe that some connection is lose & needs to be soldered.
But I can't seem to open it. The only video I have found is this: http://www.youtube.com/watch?v=eq2VthZxsts
The guy in the video claims that there are two notches in the base which could be used. In my Toothbrush, the notches are in soft rubber like material, so I can't use them to open it. Does anyone have any ideas?
rickharris6 years ago
THE BOTTOM UNSCREWS.
dev3 (author)  rickharris6 years ago
That's what I saw in the linked video as well..But how do I unscrew it?
zamiere dev36 years ago
Image from pdf: http://awesomescreenshot.com/0b29wjfb4
http://www.oralb.com/assets/pdf/vitality_instructions.pdf
Plug the top end to the hole in chargers back side and turn it ccw.
My charger is breaked when I tried it... Use vise if it happens, care with direction!
orksecurity6 years ago
Suggestion: Hit Braun's website, look for owner's manual for your model, and within that look for recycling instructions. Those will probably tell you how to open it up to extract the batteries for environmentally appropriate disposal.
If you're lucky, that process will be reversible.
I just looked at our newish oral B and see the body is now oval so unscrew may well be wrong - The old one was round and I did unscrew and replace the battery.
Possibly the whit pip on the front is a release button.
The bottom has an O ring in the seal it water tight so it will be hard to get out anyway.
