How do I brace my garage door so the garage door opener doesn't warp the door where attached to the opener?
I have a one car garage door I'm installing a garage door opener to. The problem is the manufacturer of the door doesn't guarantee the vertical aluminum center bar on the top panel of the door won't bend or break during the operation of the garage door opener. How can I brace the L-shaped aluminum bar to take the stress of the door being automatically lifted without warping the bar or the top panel of the door? There is no information listed on the garage door manufacturer's website.
Feb 23, 2011. 3:39 PMgaragedoorparts says:
frollard is right, you need to reinforce your panel to keep it straight.. even for safety reasons. the exact part you may be looking for is pictured here: Garage Door Strut
That's based on my understanding of what you are asking..
Cheers,
Dave
Oct 15, 2009. 11:03 AMblasterboy says:
Hi Attach a oversize metal plate with stove bolts under where theoperator attaches to the door to raise and lower the panels,attachoperator bracket over plate, drill through plate then attach withbolts,also lube the hinges and track this should take care of any bind.Ron
Jun 8, 2009. 7:32 AMfrollard says:
There is a metal strip that is under tension to help keep the panel straight - called struts. I'm not sure what part of the door you're referring to.
http://www.garagedoorpartsllc.com/ has a picture with descriptions.
Jun 7, 2009. 9:49 PMNachoMahma says:
. If the counter-balance springs on the door are set properly, it shouldn't be a problem. I've seen metal plates used for reinforcement.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
