loading
How do I build a device that will control the air supply going into a charcoal smoker to keep the heat constant?
Leaf Blower
hiimed (author)  shotgunshane4 years ago
I've used a leaf blower in the past to get coals started in my grill. It's a little aggressive but gets the job done.
Yes it will do it pretty fast
Temp probe connected to a micro controller that can turn a fan on and off with the temp changes.
You may/should be able to buy a thermo probe that has the ability to switch electrical items on and off eg a fan.
What sort of temperature range are you talking about? The smoking I have seen is at a very low temperature and you could use a simple room stat.
hiimed (author)  rickharris4 years ago
There are a few commercially made devices to accomplish this but i'd like to get by for under $100.
blkhawk hiimed4 years ago
Maybe connect the temp probe already mentioned to a servo motor acting on a  throttle , thus controlling the air intake of your grill.
hiimed (author) 4 years ago
Yes, I;d like it to be automatic. I'd like to set the temperature and have it hold it. I've been doing some research since I asked the question. I think I'm looking for a PID controller and a relay. I just need to know how to wire it up and program it.
I will come with a data sheet showing how to wire it. you may be able to access the data sheet on line.
Do you want this to be automatic?
