How do I connect s-video male plugs to Cat-3? 6 connector cabling in order to combine 2 separate security camera systems
110100101108 years ago
check out here the connection map of s-video
most likely your cameras transmit the standard 4-entry s-video or (if they dont have color) maybe only the intensity (then you may not have to connect the color wire)
use a twisted pair for each wire and is earth. sharing earth wires or using a twisted pair of wires for 2 cameras may add noise to the image or make it disappear
if you see that there is noise no matter what you do try cat 5 / 7 or tv coax cable instead
