loading
How do I convert a 240v pond/filter pump to solar power?
I don't have any particular type of 240v pump/filter in mind but do know that it will be small.  The actual pond is a decorative water feature and holds maybe 30 litres.
Re-design7 years ago
If you haven't bought it then get a 12v. pump.  Getting solar power up to 240v. is going to be expensive and waste a lot of the power you capture.
If you want to also be able to run it on 240 then you can use a transformer to bring it down.
Seconded;  Use the smallest voltage appropriate sized pump, then build the solar array to suit.
