loading
How do I hook my gas water heater to a wood stove safely?
I heat my house with a barrel stove(w/plenum surround) that is in my basement. My propane water heater is 3 feet away and I wonder if I can add a coil of sometype and connect to the water heater and be able to control the water temp. Are there any plans out ther? Thanks for your help, David
seandogue7 years ago
I suppose you could route the cold water thru a coil and then into the water heater, using the wood stove as a preheater...would need few additional components (maybe a one way valve and a pressure relief between the coil and inlet on the water heater), so no significant added cost or complexity that might be associated with a secondary controller. I don't know of any plans specifically and am speaking off the of of my head. However, having said that I'm sure there are.
btw I got quite a few hits on "preheat with wood stove" on a quick yahoo search"..(hint)
Is a propane water heater a big tank, or is it an instant thing ?
