How do I know what size breaker to use for 12 volt 5 amp/hour SLA ?
I found a 3 amp snap in circuit breaker.  It says 3A-32V.  Does that mean 3 amps up to 32 volts or 3 amps at only 32 volts? The guy I bought it from wasn't sure.  He believed the volts could be anywhere between 1 and 32  and would flip the breaker at 3 amps anywhere in that voltage range.  In other words, 2 volts at 3 amps flips it, 12 volts 3 amps flips it , 24 volts 3 amps flips it, etc.  Is that how breakers work?
Sorry about the backwardness.  I took the pic with my mac.
Airsoft 007 Sniper says: Oct 30, 2010. 1:27 PM
To test use ohms law...
V=IR
test voltage of battery
12(ish) = 4Amps * x
12/ 4 = 3 Ohms
Short it out against a 3 ohm resistor and you'll be sure to draw 4 amps
12 volts times 4 Amps = 48 watts, so use a beefy resistor, be sure to do it for only a short time and/or expect it to be a sacrificial resistor...see if that pops it.
If it works the same as every fuse I've seen it senses heat with a bimetal strip, and that would be wattage not just pure amperage.
If it senses current electronically then sure, 3 amps is 3 amps.
neffk says: Dec 1, 2010. 4:59 PM
Those are maximum figures. It's made for low voltages and relatively large currents.
Your application is probably not as 32 V, so you can compute the power 3A * 32V = 96 Watts. Plug in the voltage and current of your project to figure out your power requirements. If you get something less than 96 W, you can use this breaker.
BTW, if there's a motor or other large inductance in the circuit, you might be in trouble even if you're under the maximum power limit.
Airsoft 007 Sniper says: Oct 30, 2010. 1:26 PM
well the lower the voltage the higher the amperage unless your using a tranformer so I'd recomend asking a local electronic or home improvement store because three amps is enough to fry you to a crisp
lemonie says: Oct 26, 2010. 3:02 PM
Yea it's the 3A, voltage is irrelevant.
L
steveastrouk says: Oct 25, 2010. 3:49 PM
3 Amps is 3 Amps.
Its UP to 32V
Steve
frollard in reply to steveastroukOct 25, 2010. 7:25 PM
That's a good question, In a traditional fuse it was assumed the fuse was for a certain voltage so that amperage going up would heat it sufficiently to fail safely. I guess that's the reason they're not rated in watts.
Noblenutria (author) in reply to frollardOct 25, 2010. 11:26 PM
I hooked it up and it does trip when I short the battery. That's good because I was mainly worried about wreaking the battery. On the other hand, it does not trip when I run something which I know draws 4 amps. I will need to do more testing.
steveastrouk in reply to NoblenutriaOct 26, 2010. 4:41 AM
It won't trip for several minutes on a 25% overload, neither will a fuse.
A CB or fuse does NOT limit currrent remember - shorting a battery with it WILL upset the battery if you do it too much.
Steve
frollard in reply to NoblenutriaOct 26, 2010. 3:50 AM
V=IR
12(ish) = 4Amps * x
12/ 4 = 3 Ohms
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
