How do I make some plaster for a craft project stepping stone at home?
 My kids and I were making these stepping stones for decoration and the plaster wasn't dry yet and my son picked it up too soon and some of it crumbled up and I need to make another one quick with stuff already in my home...
spaul16 years ago
Follow these action-by-action instructions and discover how to make your own garden stepping stones. Collect all your supplies and then you are all set to start! Stick to these simple and easy strategies and also refer to the ideas on the provide web page and hints and suggestions pages. The first of all matter you should really do is to defend your operate surface and all by yourself. Lay down some newspaper, plastic sheeting, or an outdated tablecloth or shower curtain. Weather conditions permitting, you can make these exterior! Normally put on eye safety and rubber gloves... An previous, very long sleeve shirt and sweatpants would also be a great concept. Set your mold on your function surface. If you are implementing a specific stepping stone mold observe any directions that arrived with it. I applied clear, plastic planter saucers as-is, and they worked best! If you are brave sufficient to experiment with a cake pan or other household merchandise, you might test coating them with a liberal layer of cooking spray or petroleum jelly. Now, you are all set to combine up the concrete. Go along with the companies directions on the bag of concrete you are implementing. I used a bag of Quikrete, which certainly had no precise directions. I uncovered that a combination of five elements concrete to 1 piece water worked nicely. Your combination will vary depending on what sort of concrete you use, but the wet mixture really should have the consistency of thick brownie batter. After your concrete is combined, you can get started in spooning it into the mildew. Fill the mildew about fifty percent total and smooth it down. Lay your reduce piece of screening or hardware cloth (as explained on the supplies page) into the mildew and then finish scooping the cement into the mold until total. Gently tap about the exterior of your mold to assist get rid of any air bubbles and also to help even out the best. Now depart your stepping stone alone to set up for 30 to sixty minutes previously you add any embellishments or decorations - this is specifically very important if you are doing hand prints or other prints in the cement. After the cement has been offered some time to set up, you can begin the process of decorating it. Use the decorating and embellishment thoughts detailed on the materials page or think of your own. If you make a mistake, you can easily remove the items, flatten out the top rated with the side of a craft stick or spoon, tap the sides to sleek, and get started in excess of all over again! Your stepping stone has to now sit for 2 - 3 days free of getting disturbed - do not transfer it. When it is dry, you can gently pop it out of the mold. Voila! Now, you can end decorating it if you are preparing on engaging in any painting. You can seal the very best of your stepping stone with a distinct acrylic sealer if you paint it. I would propose letting your stepping stone sit for an additional week prior to putting it exterior. When you location the stones outside they ought to not be raised previously mentioned ground far more than about one/two-inch so many people don't trip on them and also so the stone doesn't break. plasterers nottingham
sanagol6 years ago
corn starch and water it dryes quiq but if i where you id and same white glue so it hardens better
orksecurity7 years ago
Websearch for "play dough" (note that I'm avoiding the brandname) and you'll find lots of recipes for a simple flour-based modelling material.
Burf7 years ago
You could try to glue the larger pieces together with white glue and then fill in the missing pieces with a paper mache made of white printer paper, water and white glue as a hardener.
frollard7 years ago
Plaster of paris is cheap from a craft store...
royal icing (icing sugar and water) solidifies rock hard, but will get sticky when wet
drywall mud takes quite a while to dry and shrinks, often cracking with thick areas, but will work to patch up broken areas.
