loading
How do I make the eraser larger on WINDOWS 7 MS paint?
Hi! Another technical problem. I've been getting into paint to try doing some manga on it and I've run into a problem. I can't make the eraser larger. I've worked with the previous paints but none of those hotkeys work. I looked it up on the internet and it said to use fn+ctrl+? but it didn't make any difference. Remember this is windows 7!
Any help?
Burf6 years ago
For large areas, use the free-form select tool and then clear the selection. The regular sized eraser will take care of the final touch-up.
Tornado96 (author)  Burf6 years ago
Since this was the most helpful answer it will get best answer. :-)
That's the problem. Say I only want to erase one colour. I can't use teh colour replacement with the free-form tool. Darn you paint...
MDM543 months ago
You can also use Windows key + Ctrl + "+" from Numpad for increasing the Eraser size and Windows key + Ctrl + "-" from Numpad for decreasing the Eraser size. I tried it on Windows 10, hope it also works for Windows 7.
ruchirarya3 years ago
Use On-Screen Keyboard who neither have alternate keys in their keyboards nor Numpad.
Steps:-
1. Search keyboard in Start Menu.
2. Open it.
3. Enable the Numpad by pressing NumLock Key.
4. Open paint and select rubber.
5. Now press (ctrl key) + (+ key from numpad); size will increase. Number of time you press both the keys, number of times the size of the rubber will increase.
Note:- Those who dont have numpad enabled in On-Screen Keyboard, enable it from settings of On-Screen Keyboard.
:) :D :P
Ann. ruchirarya6 months ago
Hi you're amazing
It was a great way and solved my problem thanks yaaar it was brilliant
ShameemS6 months ago
Did Google ever do this to you?
infyz1 year ago
To increase Ctrt+Fn+/(?)
To decrease Ctrt+Fn+;(:)
Selainq2 years ago
which is the short key for auto sum in excel 2007
Its working 100%. Thanx bro..
mfnaqvi3 years ago
Note that Numeric Pad is available on your Laptop Keyboard, as shown in following Image, so:
1. Enable Number Lock on your Laptop by pressing Fn & NmLk Keys
2. Press Ctrl & I  Keys to increase the size
3. Press Ctrl & ; Keys to decrease the size
perlcoder4 years ago
I've just had the opportunity to do this on a Dell Laptop using Windows 7 x64 and Paint.
To increase the size of the eraser, press FN-CTRL-+ (keypad +, not keyboard +).
The FN key tells the keyboard that you wish to use the alternate keys (in this case keypad). I have not tested this on a full sized keyboard, but I assume that ctrl-+ will work when the + key is located on the keypad instead of the +/= key on the keyboard.
sroy115 years ago
control(ctrl) button plus + (plus) for large - for small
lemonie6 years ago
Use a (real) pen/pencil & eraser instead.
L
rickharris6 years ago
Select eraser and then select the size pull down. Even at it's biggest it isn't very big
if ur on a laptop take two fingers together and slowly drag them apart on the trackpad
frollard6 years ago
In the old version there was ctrl +-, but I don't think the 7 version has that. :(
