I am wanting to build a lathe for turning larger projects (hollow wooden shells: up to 29" wide, about 30"-32" long, 1.5" thick all the way around). I have the motor, belts, drive wheels, etc... I just need to know what would be the best for mounting or housing a taper bearing. Would I absolutely need two of them (or more)? I am using a taper bearing because it is better for handling larger weight and stress.
Another idea: I once took apart a gear reducer unit that had a dual output shaft, The output shaft had taper bearings on each end, The output shaft was driven by a worm gear on a shaft which was perpendicular to the output shaft.If the worm gear shaft was removed ,you would then have a free spinning output shaft, and could mount a pulley on one end and screw plate or chuck on the other end to hold the work piece.
I did some looking into these gear reducers with dual output shafts and shopped around and found this to be very helpful, thank you! It is definitely turning into a larger hassle than what it is worth for building from scratch as others have mentioned and I thank you all! RavensCraft, the dual output shaft is very ideal and would seem to work perfectly in the manner as you suggested with mounting a pulley on one end and the faceplate on the other after removing the perpendicular gear shaft.
What machine shop access have you got ? I'd be tempted to buy big "plummer blocks" for a simple wood lathe, rather than the hassle of building a full machine bearing.
Warning! I am not a mechanical engineer but I think your front bearing should be tapered to withstand the thrust generated by turning and the rear can be a straight bearing to support the back of the shaft.
Many old lathes had simple white metal bearings and apart from needing adjusting on occasion worked fine.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
http://www.vintageprojects.com/lathe-milling-plans.html
has several sets of old plans for lathes.
Here's a Youtube video:
https://www.youtube.com/watch?v=EyPtidlauNs
